title: GPU Mode missing for compatible AMD GPUs
description: Troubleshooting for a missing GPU Mode button despite having a compatible AMD GPU
[Skip to content](https://support.keyshot.com/en/knowledge-base/gpu-mode-missing-for-compatible-amd-gpus#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
 Tell us what's happening
# GPU Mode missing for compatible AMD GPUs
## Troubleshooting for a missing GPU Mode button despite having a compatible AMD GPU
Issue
Despite having an AMD GPU that is
- RDNA 3 architecture and newer
- Radeon RX 7600 or above
- Minimum driver version: **23.30**
 the GPU Mode button is missing.
 ![](https://support.keyshot.com/hs-fs/hubfs/image-png-Jun-17-2026-12-11-16-1799-PM.png?width=513&height=113&name=image-png-Jun-17-2026-12-11-16-1799-PM.png)
### Environment Details
- KeyShot
    - 2025.3 and newer
- Compatible AMD GPU
- Driver version 26.5.1+
### Troubleshooting
We've discovered that AMD has stopped shipping ROCm 6 required for the HIP runtime 6 as of driver version 26.5.1.
The effect in KeyShot Studio is that the Device Enumeration will fail, and the GPU button will be missing.
The solution is to install an older driver first, and then update, as that should then allow the version 6 module to persist.
 We'll be looking into supporting HIP runtime version 7 for 2026.3.
For KeyShot 2026.2:
- First, downgrade to the driver version 26.3.1, or to be safe to version 25.12.1
- Then upgrade to the new version
keyshot.com Help Center
Copyright © 2026, KeyShot
