title: How to Increase the Height of the Animation Panel
description: How to increase height of Animation Panel
[Skip to content](https://support.keyshot.com/en/knowledge-base/how-to-increase-the-height-of-the-animation-panel#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
 Tell us what's happening
2. [Learning Content](https://support.keyshot.com/en/knowledge-base/learning-content?hsLang=en)
3. [Quick Tips](https://support.keyshot.com/en/knowledge-base/learning-content?hsLang=en#quick-tips)
# How to Increase the Height of the Animation Panel
## This article will go through the steps of how to increase the height of the Animation panel while it is still docked within KeyShot
 There are a few ways to increase the height of the Animation panel while it is still docked within KeyShot but there are a few limitations.
### Prerequisites
- KeyShot
    - Any version with Animation
### Procedure
The Animation Panel may appear small on your screen depending on your Display Resolution and the size of your real-time view. Adjusting both of these may allow you to drag the Animation panel up higher so that the height is increased.
It is also possible to slightly increase the height of the Animation pane by hiding the Toolbar or Ribbon. You can do this by going to the Window dropdown menu in KeyShot and deselecting the Toolbar and Ribbon.
### Additional Resources
- You can find more information regarding the Animation Panel and the Window settings in the Manual[here](https://manuals.keyshot.com/kss2025/manual/main-menu.html).
keyshot.com Help Center
Copyright © 2026, KeyShot
