title: KeyShot crashes when dragging or changing Materials on MacOS
description: Troubleshooting for unexpected crashes when dragging or changing Materials on MacOS
[Skip to content](https://support.keyshot.com/en/knowledge-base/keyshot-crashes-when-dragging-or-changing-materials-on-macos#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
 Tell us what's happening
# KeyShot crashes when dragging or changing Materials on MacOS
## Troubleshooting for unexpected crashes when dragging or changing Materials on MacOS
### Issue
When altering or drag and dropping Materials in KeyShot Studio 2026 on MacOS, KeyShot might crash unexpectedly.
### Environment Details
- KeyShot
    - 2026.1+
- MacOS
### Troubleshooting
This might be known bug in the version of Qt (6.8.2) that we are using. A workaround for this known bug is to disable the accessibility feature in Qt, using an environment variable: QT\_ACCESSIBILITY
Set the value of that environment variable to simply “0” (without the quotes) before starting KeyShot Studio.
1. Open the Terminal
     - Press Cmd (⌘) + Space
     - Type Terminal and press Enter
   or
     - Open Finder
     - Go to Applications → Utilities
     - Double-click Terminal
2. In the Terminal, type `launchctl setenv QT_ACCESSIBILITY 0`
   and press Enter, then start KeyShot Studio
3. from the Terminal by entering
   `QT_ACCESSIBILITY=0 "/Applications/KeyShot Studio.app/Contents/MacOS/keyshot"`
   Replace `/Applications/KeyShot Studio.app` with the actual path of the app on your disk.
That method is only for a quick test to confirm that the workaround fixes the crashes, as the environment variable will not persist that way (and will not apply to the KeyShot Studio app launched through the Dock).
### Resolution
If this indeed fixes the crashes, a more permanent way of setting the environment variable would be like this:
Create a text file and enter the following:
![](https://support.keyshot.com/hs-fs/hubfs/image-png-Jun-17-2026-04-44-02-2371-PM.png?width=670&height=286&name=image-png-Jun-17-2026-04-44-02-2371-PM.png)
\<?xml version="1.0" encoding="UTF-8"?\>
\<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "[http://www.apple.com/DTDs/PropertyList-1.0.dtd](http://www.apple.com/DTDs/PropertyList-1.0.dtd)"\>
\<plist version="1.0"\>
\<dict\>
\<key\>Label\</key\>
\<string\>com.keyshot.env\</string\>
\<key\>ProgramArguments\</key\>
\<array\>
\<string\>launchctl\</string\>
\<string\>setenv\</string\>
\<string\>QT\_ACCESSIBILITY\</string\>
\<string\>0\</string\>
\</array\>
\<key\>RunAtLoad\</key\>
\<true/\>
\</dict\>
\</plist\>
Make sure to save it as a plain text and rename it to **com.keyshot.env.plist**
Or download it [here](https://support.keyshot.com/hubfs/Support/Uploads/Upload%20-%20Nik%20-%20Article%20Stuff/com.keyshot.env.plist.txt?hsLang=en)
Place the file in
~/Library/LaunchAgents/
Lastly, using the Terminal, type the following command, which will re-run launchctl setenv automatically at every login:
 `launchctl load ~/Library/LaunchAgents/com.keyshot.env.plist`
### Resolution
Remote-access / screen-sharing tools are exactly the class of software that injects accessibility and Cocoa hooks into other processes. Could you please fully quit and retest without:
- **Remote-access / screen-sharing tools** (HP Anywhere, TeamViewer, AnyDesk, Zoom screen share, etc.)
- Screen recorders, camera/streaming utilities
- Window managers (Rectangle, Magnet), clipboard managers, text expanders, BetterTouchTool
- Any corporate security/EDR agent that hooks the UI
keyshot.com Help Center
Copyright © 2026, KeyShot
