title: KeyShot Crashes When Using Shift+Click to Marquee-Select Surfaces After Splitting Object Surfaces
description: Learn how to fix KeyShot crashes caused by Shift+Click marquee surface selection after splitting object surfaces in version 2025.2, and why updating to 2025.3 resolves the issue.
[Skip to content](https://support.keyshot.com/en/knowledge-base/keyshot-crashes-when-using-shiftclick-to-marquee-select-surfaces-after-splitting-object-surfaces#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
 Tell us what's happening
# KeyShot Crashes When Using Shift+Click to Marquee-Select Surfaces After Splitting Object Surfaces
## Unexpected application crash when marquee-selecting surfaces using Shift + Click after applying Split Object Surfaces.
#### **Issue Description**
Some users may experience KeyShot unexpectedly closing with no error message when attempting to marquee-select multiple surfaces after using the **Split Object Surfaces** feature. The crash occurs immediately upon releasing the mouse button after dragging a selection box with **Shift + Click**.
The issue may also occur in the main render viewer when using **Shift + Click + drag** to marquee-select multiple parts.
#### **Environment**
- KeyShot 2025.2
- Windows OS
- GPU or CPU mode (issue occurs regardless of rendering mode)
#### **Cause**
The exact trigger is inconsistent, but the issue is related to an instability in KeyShot 2025.2 that occurs when performing marquee surface selection after splitting object surfaces. Selecting surfaces **one at a time** does **not** cause the crash, only marquee-style selection does.
This behavior was resolved by fully reinstalling KeyShot and updating to **KeyShot 2025.3**, which includes stability improvements that prevent the crash.
#### **Resolution**
### Recommended Fix: Update to KeyShot 2025.3
Updating to the latest KeyShot version fully resolves the issue. Users who updated to **KeyShot 2025.3** reported that the crash no longer occurs.
**Additional Notes:**
If you continue to experience issues after updating, please contact KeyShot Support with your logs, system details, and reproduction steps.
keyshot.com Help Center
Copyright © 2026, KeyShot
