title: KeyShot Network Rendering Logs
description: How to get Network Rendering logs for Support.
[Skip to content](https://support.keyshot.com/en/knowledge-base/knowledge/keyshot-network-rendering-logs#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
 Tell us what's happening
# KeyShot Network Rendering Logs
## How to get Network Rendering logs for Support.
When you are having issues with KeyShot Network rendering Manager and Workers not connecting or starting a job, send us your log files for further investigation. The log files would help us with finding any errors you may be experiencing with connections or jobs not wanting to start.
### Prerequisites
- KeyShot Network Rendering
    - Network Rendering Logs
          - Manager logs
          - Workers Logs
### Procedure
1. Access the computer acting as the Network Manager.
     1. Access the computer acting as the Network Worker.
2. Browse to the Network rendering Log folder:
     - Windows: *C:\\Users\\Public\\Public Documents\\KeyShot Network Resources\\Logs*
           - *You will find logs named KeyShot Manager / Worker / Watchdog / Configuration*
     - Mac OS: *Macintosh HD\\Library\\Application Support\\KeyShot Network Resources\\Logs*
     - Linux: */var/local/share/KeyShot11NetworkResources*
3. Please send both Manager and Worker logs in a ZIP file.
     - If you send the Logs folder that would give us all current logs created.
### Additional Resources
- You may send it securely via our [WeTransfer](https://keyshot.wetransfer.com/?title=Ticket%20ID:%20{{ticket.hs_ticket_id}}%20{{ticket.subject}}&msg=Your%20Ticket%20ID:%20{{ticket.hs_ticket_id}}%0ASupport%20Agent:%20{{ticket.hubspot_owner_id}}&to=support-3@keyshot.com.hs-inbox.com)
- [Linux Trace Logs](https://support.keyshot.com/en/knowledge-base/knowledge/network-rendering-for-linux?hsLang=en)
keyshot.com Help Center
Copyright © 2026, KeyShot
