title: Missing BIP preview from Thumbnails
description: This article provides guidance on what to do when uninstalling an older version of KeyShot while a newer version is already installed, as this can cause the Preview to be removed from BIP files
[Skip to content](https://support.keyshot.com/en/knowledge-base/knowledge/missing-bip-preview-from-thumbnails#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
 Tell us what's happening
# Missing BIP preview from Thumbnails
## This article provides guidance on what to do when uninstalling an older version of KeyShot while a newer version is already installed, as this can cause the Preview to be removed from BIP files
### **Issue**
When uninstalling an older version of KeyShot while a newer version is installed it can remove the Preview from BIP files.
### **Environment Details**
- KeyShot Studio
    - Any version while a newer version is already installed
### **Resolution**
Two options for fixing missing Thumbnails:
1\. You can re-run the full KeyShot installer and install over your current KeyShot Installation. No need to uninstall current KeyShot installation.
2\. You can register the Preview handler found in the KeyShot bin folder. Open Command Prompt in  administrator mode.
Type in:
1. cd C:\Program Files\KeyShot9\bin\2. Enter key3. regsvr32 KeyShot-ih.dll4. Enter key5. The registry should Succeed.
**Additional Note**
- You may need to adjust the path to point to your installation directory.
- More common to happen with updated installers being used.
### **Additional Resources**
If the above steps don't resolve the issue you can follow more advanced steps to resolve the issue. Follow [this link here](https://help.keyshot.com/support/solutions/articles/60000690417-missing-bip-thumbnail-advance-troubleshooting).
keyshot.com Help Center
Copyright © 2026, KeyShot
