title: "Error: This application failed to start because no Qt platform plugin could be initialized"
description: After installing KeyShot for the first time, when trying to launch the program, the error occurs - no Qt platform plugin could be initialized
[Skip to content](https://support.keyshot.com/en/knowledge-base/no-qt-platform-plugin-could-be-initialized#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
 Tell us what's happening
# Error: This application failed to start because no Qt platform plugin could be initialized
## After installing KeyShot for the first time, when trying to launch the program, the error occurs.
### Issue
After installing KeyShot for the first time, when trying to launch the program, the below error occurs.
![](https://support.keyshot.com/hs-fs/hubfs/5y3dUPMIDEGfriJNiqYU0Wfho80q-N8ECw-png.png?width=597&height=262&name=5y3dUPMIDEGfriJNiqYU0Wfho80q-N8ECw-png.png)
### Environment Details
- KeyShot
    - 2023/2024
- SolidEdge
### Cause
- If SolidEdge is installed prior to KeyShot it appears to cause an issue with the launching of KeyShot for the first time.
### Resolution
Uninstalling SolidEdge, then reinstalling KeyShot should resolve this issue. You can reinstall SolidEdge once KeyShot is activated.
keyshot.com Help Center
Copyright © 2026, KeyShot
