title: "SSO Authentication Failure: \"Failure when receiving data from the peer\""
description: "Troubleshooting for the SSO Authentication Failure: \"Failure when receiving data from the peer\""
[Skip to content](https://support.keyshot.com/en/knowledge-base/sso-authentication-failure-failure-when-receiving-data-from-the-peer#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
 Tell us what's happening
3. [Subscription](https://support.keyshot.com/en/knowledge-base/license-support?hsLang=en#subscription)
# SSO Authentication Failure: "Failure when receiving data from the peer"
## Troubleshooting for the SSO Authentication Failure: "Failure when receiving data from the peer"
### Issue
When trying to activate KeyShot Studio, the following error occurs when signing in to KeyShot:
Authentication state: Unauthenticated
Message: "SSO Error: Failure when receiving data from the peer"
![](https://support.keyshot.com/hs-fs/hubfs/image-png-Jun-17-2026-03-25-13-1535-PM.png?width=400&height=287&name=image-png-Jun-17-2026-03-25-13-1535-PM.png)
### Environment Details
- KeyShot
    - 2026.1+
- Subscription License
### Troubleshooting
Please check if you can access [https://login-configuration.keyshot.com/](https://login-configuration.keyshot.com/) in your browser. If you get a response in the browser but KeyShot fails to sign in, the error is likely caused by a corporate firewall or security appliance blocking HTTPS POST requests to https:// [login.keyshot.com/oauth2/token](http://login.keyshot.com/oauth2/token).
### Resolution
Have your IT department ensure the following endpoints are allowlisted for **HTTPS POST traffic** (not just GET):
- [https://login.keyshot.com/oauth2/token](https://login.keyshot.com/oauth2/token)
The exact IPs used can be found in `auth_cache.json`. The default file location is:
- **Windows:** `%APPDATA%\KeyShot\auth_cache.json`
- **macOS:** `~/Library/Application Support/KeyShot/auth_cache.json`
  "authUrl": "https://login.keyshot.com/oauth2/authorize",
  "beta": true,
  "clientId": "xxxxxxxxxxx",
  "clientName": "keyshot",
  "configUrl": "https://login-configuration.keyshot.com/",
  "localhostFailureRedirectUri": "https://app.keyshot.com/sign-in/failure",
  "localhostPorts": \[
    30794,
    31017,
    31672,
    33552,
    33771,
    34393,
    34626,
    35353,
    39419,
    39503
  "localhostSuccessRedirectUri": "https://app.keyshot.com/sign-in/success",
  "loginRedirectUri": "https://app.keyshot.com/logged-in/keyshot/beta",
  "logoutRedirectUri": "https://app.keyshot.com/signed-out/keyshot/beta",
  "logoutUrl": "https://login.keyshot.com/logout",
  "proxySettings": {
    "enableAuthentication": false,
    "host": "localhost",
    "obfuscatedPassword": "",
    "port": 8080,
    "proxyType": 2,
    "username": ""
  "revocationUrl": "https://login.keyshot.com/oauth2/revoke",
  "tokenUrl": "https://login.keyshot.com/oauth2/token",
  "userInfoUrl": "https://login.keyshot.com/oauth2/userInfo"
Add the following KeyShot URLs to the Firewall Whitelist for the organization using this [KB article](https://support.keyshot.com/en/knowledge-base/whitelist-firewall-settings-for-keyshot-products?hsLang=en).
keyshot.com Help Center
Copyright © 2026, KeyShot
