AI Shots not downloading or AI Engine not Starting
A guide for troubleshooting the AI Model not downloading or the Engine not starting.
Environment Details
- KeyShot Studio
- 2025.2
- 2025.2
Issue 1: AI Shots not available
When clicking on the button AI Shots, instead of prompting the download, you may get an error that AI Shots is not available.
Cause
This error is likely due to lacking permission to write to the AppData folder.
Resolution
- Please manually create the folder named "ai_models" in the AppData folder.
Windows:
- Installed Just For Me:
%LocalAppData%\Luxion\KeyShot Studio\ai_models or
C:\Users\<username>\AppData\Local\Luxion\KeyShot Studio\ai_models - Installed For Everybody:
%AllUsersProfile%\Luxion\KeyShot Studio\ai_models or
C:\ProgramData\Luxion\KeyShot Studio\ai_models
macOS:
- /Users/<Username>/Library/Application Support/Luxion/KeyShot Studio/ai_models or
~/Library/Application Support/Luxion/KeyShot Studio/ai_models
- If you have a firewall or antivirus running, please set exceptions or add KeyShot to the trusted applications.
- After creating the folder, please restart KeyShot and click on the AI Shots button again.
Issue 2: Failed to start the AI engine
When clicking on the button Start AI Engine, you may encounter an issue
Cause
This error is caused by special characters being present in the directory to the ai_models folder.
Resolution
A proper patch will be available at a later point, but in the meantime, please download the build with the manual auth handler bypass and a fix to special characters in the path to the ai_models folder.
