title: Learning Content | Support Knowledge Base
description: Learning Content
[Skip to content](https://support.keyshot.com/en/knowledge-base/learning-content#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
[My Inbox](https://support.keyshot.com/tickets-view)
 Tell us what's happening
1. [Support Knowledge Base](https://support.keyshot.com/en/knowledge-base)
2. [Learning Content](https://support.keyshot.com/en/knowledge-base/learning-content)
# Learning Content
- [FBX Export Does Not Include Separate Texture Folder](https://support.keyshot.com/en/knowledge-base/fbx-export-does-not-include-separate-texture-folder)
- [Applying Physical Lights as Materials Replaces or Moves Components](https://support.keyshot.com/en/knowledge-base/applying-physical-lights-as-materials-replaces-or-moves-components)
- [Rendering Menu or Render Queue Not Visible on Desktop Device](https://support.keyshot.com/en/knowledge-base/rendering-menu-or-render-queue-not-visible-on-desktop-device)
- [Material Library Color Name Displays With “#1” After Applying to Scene](https://support.keyshot.com/en/knowledge-base/material-library-color-name-displays-with-1-after-applying-to-scene)
- [Locked Materials in KeyShot Studio Library](https://support.keyshot.com/en/knowledge-base/locked-materials-in-keyshot-library)
## Webinars
- [A Guide to Efficiently Working with Materials](https://support.keyshot.com/en/knowledge-base/knowledge/webinar-67-the-efficient-keyshot-user-materials)
- [KeyShot Product Rendering Start-to-Finish](https://support.keyshot.com/en/knowledge-base/knowledge/webinar-81-keyshot-product-rendering-start-to-finish)
## Quick Tips
- [Rotation Animations with arbitrarily oriented geometry](https://support.keyshot.com/en/knowledge-base/rotation-animations-with-arbitrarily-oriented-geometry)
- [Quick Tip: Randomizing Specific Colors](https://support.keyshot.com/en/knowledge-base/quick-tip-randomizing-specific-colors)
- [How to Increase the Height of the Animation Panel](https://support.keyshot.com/en/knowledge-base/how-to-increase-the-height-of-the-animation-panel)
- [Can Multiple Textures be automatically assigned?](https://support.keyshot.com/en/knowledge-base/can-textures-be-automatically-assigned)
- [Animate an Assembly Explosion](https://support.keyshot.com/en/knowledge-base/animate-an-assembly-explosion)
- [QuickTip: Pivot Points](https://support.keyshot.com/en/knowledge-base/knowledge/quicktip-pivot-points)
- [KeyShot UV Unwrap](https://support.keyshot.com/en/knowledge-base/knowledge/keyshot-uv-unwrap)
See less ▼
- [Technical Support](https://support.keyshot.com/en/knowledge-base/technical-support#main-content)
    - [KeyShot Studio](https://support.keyshot.com/en/knowledge-base/technical-support#keyshot-studio)
    - [Network Rendering](https://support.keyshot.com/en/knowledge-base/technical-support#network-rendering)
    - [KeyVR](https://support.keyshot.com/en/knowledge-base/technical-support#keyvr)
    - [Plugins](https://support.keyshot.com/en/knowledge-base/technical-support#plugins)
    - [How-To](https://support.keyshot.com/en/knowledge-base/technical-support#how-to)
    - [KeyShot Hub](https://support.keyshot.com/en/knowledge-base/technical-support#keyshot-hub)
    - [KeyShot Web](https://support.keyshot.com/en/knowledge-base/technical-support#keyshot-web)
- [License Support](https://support.keyshot.com/en/knowledge-base/license-support#main-content)
    - [Node-Lock](https://support.keyshot.com/en/knowledge-base/license-support#node-lock)
    - [Floating](https://support.keyshot.com/en/knowledge-base/license-support#floating)
    - [Subscription](https://support.keyshot.com/en/knowledge-base/license-support#subscription)
- [FAQs](https://support.keyshot.com/en/knowledge-base/faqs#main-content)
    - [General FAQs](https://support.keyshot.com/en/knowledge-base/faqs#general-faqs)
    - [Key VR](https://support.keyshot.com/en/knowledge-base/faqs#key-vr)
    - [KeyShot Studio FAQ's](https://support.keyshot.com/en/knowledge-base/faqs#keyshot-studio-faqs)
    - [KeyShot Web FAQ's](https://support.keyshot.com/en/knowledge-base/faqs#keyshot-web-faqs)
    - [KeyShot Network Rendering FAQ's](https://support.keyshot.com/en/knowledge-base/faqs#keyshot-network-rendering-faqs)
    - [KeyShot WebViewer](https://support.keyshot.com/en/knowledge-base/faqs#keyshot-webviewer)
- [Announcements](https://support.keyshot.com/en/knowledge-base/announcements)
- [Learning Content](https://support.keyshot.com/en/knowledge-base/learning-content#main-content)
    - [Webinars](https://support.keyshot.com/en/knowledge-base/learning-content#webinars)
    - [Quick Tips](https://support.keyshot.com/en/knowledge-base/learning-content#quick-tips)
- [Downloads](https://support.keyshot.com/en/knowledge-base/downloads)
- [Best Practices](https://support.keyshot.com/en/knowledge-base/best-practices)
keyshot.com Help Center
Copyright © 2026, KeyShot
