Error: "No geometry retrieved from 'location' (Error code 7)" with Sonoma 14.4 and KeyShot 10.2
This article guides troubleshooting and resolving the "(Error code 7) File version may be unsupported" issue when importing a CAD file
Issue
When trying to import a CAD file, usually step files or SolidWorks-related files, the user will get the below error, even though they were previously able to import these files.
No geometry retrieved from... Possible causes: File version may be unsupported. You may need to export polygonal data from your modeling system.
On Mac
On Windows
NOTE: support@luxion.com email is no longer monitored
Environment Details
- KeyShot
- Version 10.2
- Version 11
- macOS Sonoma
- Version 14.4.1
- Windows
- Windows 10+
- Any CAD software but usually SolidWorks or Creo
- Creo - Any version
- SolidWorks 2023
Cause
- The upgrade to Sonoma 14.4.1 appears to have caused a bug that caused the import to throw this error.
- Error code 7 occurs when using an unsupported CAD version with KeyShot.
Resolution
On Mac
This has been confirmed as a known bug that affects users on KeyShot 10.2 and Sonoma 14.4. This has been fixed on KeyShot 2024.1 or higher.
Upgrade to our newest version of KeyShot. Please reach out to sales@keyshot.com to get more information on how you can upgrade.
Workaround 1
Downgrade your macOS to an older version other than Sonoma.
Workaround 2
Try converting your files to a different format such as .stl files.
On Windows
Workaround 1
Downgrade to Solidworks 2022.
Workaround 2
Upgrade to KeyShot 2023.1 or later.
Workaround 3
Use the KeyShot Plugin for Solidworks (the plugins use a different technology than the importer and will often not have these limitations.).
Please open a ticket on our support portal if you have any more questions.
![keyshot-logo-blk-3d.png]](https://support.keyshot.com/hs-fs/hubfs/keyshot-logo-blk-3d.png?height=40&name=keyshot-logo-blk-3d.png)
