title: "Error: Plugin Folder is Invalid"
description: plugin folder is invalid error when trying to open KeyShot
[Skip to content](https://support.keyshot.com/en/knowledge-base/error-plugin-folder-is-invalid#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
 Tell us what's happening
# Error: Plugin Folder is Invalid
## After installing KeyShot, when trying to open the application the error 'Plugin Folder is Invalid' shows
#### Issue
#### This issue specifically occurs on MacOS.
#### After installing KeyShot, when trying to open the application the error 'Plugin Folder is Invalid' shows as below:
![ed8c6a27-0543-4d6b-b316-d5538b9ac5e4-TICKET.attachments-Screenshot-2025-07-30-at-11.33.31-AM.png](https://api-na1.hubspot.com/filemanager/api/v2/files/193669007021/signed-url-redirect?portalId=2757257)
### Environment Details
- KeyShot
    - Any version
- MacOS
    - Any version
### Cause
- An issue may have occurred during installation
- The error can also be related to having more than one version of KeyShot installed on the computer. It may be referencing the Resource folder of the older version.
### Resolution
We recommend the following solutions:
**Solution 1**
Please try a fresh install using the full installer:
1. Uninstall *KeyShot.*
   ***Mac**: Uninstall by going to the Applications folder and Deleting the KeyShot app.*
2. Make sure to delete the *KeyShot*  resources folder
   **Note:** Move it to the desktop if you wish to back up your resources.
   Mac Default:
   /Library/Application Support/KeyShot
3. Download and Re-install *KeyShot* using the links below.
   For this step, you’ll need the **full installer** (not the "update" installer).
   You can find the newest version of KeyShot [here.](https://www.keyshot.com/resources/downloads/) You will need to either enter your information or login to your KeyShot Cloud Account to access the installers.
   You can find older versions of KeyShot [here.](https://www.keyshot.com/resources/downloads/previous-versions/)
4. Go through the registration wizard, enter your license information, and *KeyShot* should be up and running.
**Solution 2**
This solution can be done in conjunction with Solution 1. We recommend uninstalling the older version of KeyShot you have on the computer.
**Solution 3**
The issue may also be related to folder permissions.
Please navigate to this folder: MacHD/Library/Application Support/KeyShot Studio
If you right-click the folder and select 'Get info', you should get a pop-up like this. Then check the 'Sharing & Permissions' settings and make sure they are set to 'Read & Write'.
![](https://api.hubspot.com/filemanager/api/v2/files/195773687093/signed-url-redirect?portalId=2757257)
keyshot.com Help Center
Copyright © 2026, KeyShot
