title: "Error: \"The subscription license code could not be verified\" when trying to activate a Network Rendering code"
description: Trying to activate the network rendering license code, but I get a License Code Not Found error.
[Skip to content](https://support.keyshot.com/en/knowledge-base/error-the-subscription-license-code-could-not-be-verified-when-trying-to-activate-a-network-rendering-code#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
 Tell us what's happening
# Error: "The subscription license code could not be verified" when trying to activate a Network Rendering code
## Trying to activate the network rendering license code, but I get a License Code Not Found error.
### Issue
When entering the Network Rendering subscription code in the Network Configurator tool, the following error occurs:
The subscription license code could not be verified. License not found (LICENSE_NOT_FOUND)
I am not able to proceed to activate the subscription key.
### Environment Details
- KeyShot Network Rendering
    - 2023.1+
### Cause
- The activation code field/Subscription license field is not usable for Network Rendering codes at the moment.
### Resolution
To activate Network Rendering with a serial code please follow the instructions below:
1. Open up the Network Configurator on the **manager** machine.
2. Go to Manager Settings.
3. Select the '**License File**' radio button and click the '**Register Key**' button.
4. Fill out the remaining information to register the key.
If you are still unable to activate your Network Rendering, please generate a request file and submit a new ticket through our [Customer Portal](https://support.keyshot.com/tickets-view?hsLang=en).
keyshot.com Help Center
Copyright © 2026, KeyShot
