Error: "Failed to get configuration from KeyShot Hub"
Customer will receive this error when trying to connect to the Hub - "Failed to get configuration from KeyShot Hub"
Issue
Users receive the following error when trying to connect to the Hub:
Environment Details
- KeyShot | KeyShot Hub
- Any versions
Cause
- HTTP (80) Port needs to be opened through the Firewall. If not, this error will occur
- May also occur if the redirect URL is not let through the Firewall
Workaround
- Open port HTTP (80) via Firewall. Developers are working to change the port to an HTTPS port.
- You should whitelist [http://*.digizuite.app/]*.digizuite.app
If you do not want to whitelist a wildcard, you need to whitelist or add a TLS inspection bypass the specific URLs that are part of the redirect when trying to access the Hub via KeyShot Studio.
If you have any questions, please open up a Support Ticket in the Support Porta.
