When using Network Rendering, some or all of the workers may fail while processing a job. There can be multiple reasons for a Failed Worker.
Prerequisites
- Network Rendering
Procedure
After a file causes the workers to fail, they are stuck in pause.
You can follow the below instructions to reactivate the failed workers:
Reactivating Failed Workers:
Assuming you are signed in on the Monitor as admin or user with the right permissions.
- Right click the worker that is in the Failed state
- Choose "Reactivate"
- The worker should then restart and no longer be in the "failed" Status
Troubleshooting:
If all the workers have failed, this indicates that there was most likely an issue with the scene itself. To test this, try the following to troubleshoot:
Try to render the same scene in KeyShot without Network rendering.
- Try to Render the same job on one of the Worker machines in KeyShot via the Queue
- Alternatively try to render it on the submitting machines
- If it also fails in Queue rendering, the issue is more general and not specific to network rendering
You can open a ticket in a support portal if you have any additional questions regarding this.
