title: "Floating License: disable Borrowing"
description: "Licenses can be borrowed for offline use.\nThe duration for which a license can be borrowed, can be specified in the license file. It is also possible to create an Options file for additional customization."
[Skip to content](https://support.keyshot.com/en/knowledge-base/floating-license-disable-borrowing#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
 Tell us what's happening
# Floating License: disable Borrowing
## Licenses can be borrowed for offline use. The duration for which a license can be borrowed, can be specified in the license file. It is also possible to create an Options file for additional customization.
### Prerequisites
- KeyShot Licensing Server
### Procedure
Setting BORROW = 0 seems to be ignored by KeyShot and FlexLM and will default to 168 hours (1week).
It is therefore advisable to set BORROW = 1 to the minimum borrow time of one hour.
Since borrowing is enabled by default by the Flexera licence generator, if borrowing needs to be restricted or disabled, a workaround is required with the use of an Options file.
You can create a file named ***LUXION.opt*** and place it into the same folder that contains the license which is in the FlexLM License folder
- C:\\FlexLM\\
- C:\\ProgramData\\Luxion\\License
- MacintoshHD\\Applications\\LuxionLicenseServer\\Contents\\License
You can use the following options
- BORROW\_LOWWATER
    - specified the amount of seats that cannot be borrowed
      *BORROW\_LOWWATER keyshot2 **5***
      this will exclude **5** KeyShot Pro licenses from being borrowed.
- MAX\_BORROW\_HOURS
    - specifies the maximum amount of hours that a license can be borrowed. It needs to be lower than the than that specified in the license file for the respective feature
      *MAX\_BORROW\_HOURS keyshot2 **1***
      this will limit the borrow time for KeyShot Pro licenses to **1** hour.
### Additional Resources
- Detailed documentation for the Options file
  https://www.keyshot.com/downloads/documents/guides/FlexLM-setup\_guide.pdf#G15.1036926
keyshot.com Help Center
Copyright © 2026, KeyShot
