title: GPU Mode Not Updating Real-Time Display in KeyShot
description: Unable to render with GPU mode and the real-time display does not update and appears frozen
[Skip to content](https://support.keyshot.com/en/knowledge-base/gpu-mode-not-updating-real-time-display-in-keyshot#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
 Tell us what's happening
# GPU Mode Not Updating Real-Time Display in KeyShot
## Troubleshooting steps when GPU mode fails to render or update the viewport
### Environment
- KeyShot Studio (11 and later)
- Windows 10 or Windows 11
- NVIDIA GPU
### Issue
When enabling GPU mode in KeyShot, the real-time display does not update and appears frozen. The object’s orange outline moves independently when zooming or toggling, but the rendered view does not refresh. CPU mode may still work but performs poorly on heavy scenes.
### Cause
This issue occurs when KeyShot is not set to use the dedicated NVIDIA GPU as the **High Performance** graphics processor in Windows Graphics Settings.
### Resolution
Follow the steps below to set KeyShot to High Performance mode in Windows:
1. **Open Windows Graphics Settings**
     - Press **Windows + I** to open the *Settings* app.
     - Go to **System \> Display**.
     - Scroll down and click **Graphics**.
2. **Locate KeyShot Executable**
     - Click **Browse** (or *Add desktop app*) and select the correct installation path:
           - **Installed for current user only**:
             `%localappdata%\KeyShot\bin\keyshot.exe`
           - **Installed for all users**:
             `C:\Program Files\KeyShot\bin\keyshot.exe`
   > **Note:** KeyShot 2023 uses a folder named `KeyShot12\bin\keyshot.exe`.
   > KeyShot 2024 and later versions use `KeyShot Studio\bin\keyshot.exe`.
3. **Set to High Performance**
     - Select **KeyShot.exe** from the list.
     - Click **Options**.
     - Under *Graphics preference*, select **High Performance**.
     - Click **Save**.
4. **Restart KeyShot**
     - Close KeyShot completely.
     - Reopen KeyShot and try GPU mode again.
### Additional Information
If GPU mode is still not working after applying these settings, confirm that your NVIDIA drivers are fully up to date from the [NVIDIA Driver Downloads](https://www.nvidia.com/download) page.
For further assistance, contact the **KeyShot Technical Support team**.
keyshot.com Help Center
Copyright © 2026, KeyShot
