How to Reinstall (Fresh Install) of KeyShot Studio
If you are experiencing issues with KeyShot Studio, sometimes the easiest solution is to try a Fresh Install
Prerequisites
  • KeyShot
    • [Any version]
Procedure
Please try a fresh install using the full installer:
A. Uninstall KeyShot
Uninstall KeyShot Studio
  • Windows: Uninstall through Add/Remove Programs.
  • Mac: Uninstall by going to the Applications folder and Deleting the KeyShot app.
B. Remove resource and application data folders
  • Make sure to delete the KeyShot  resources folder
    NOTE: Move it to the desktop if you wish to back up your resources.
    Windows Default:
    • Installed Just For Me:
      %UserProfile%\Documents/KeyShot Studio or
      C:\Users\<username>\Documents\KeyShot Studio
    • Installed For Everybody:
      C:\Users\Public\Documents\KeyShot Studio or
      %Public%\Documents\KeyShot Studio
    For older versions, replace Studio with the version number, e.g. KeyShot 12 for KeyShot 2023, KeyShot 11, etc.
    Please note that that for the settings this is always the default location, regardless of where the Resource Folder was installed. It will always be there unless changed through the registry entries.
    Mac Default:
    Library/Application Support/KeyShot Studio
    *NOTE:
    There are two library folders on the Mac. One is a hidden folder and the other isn't.
    ~/Library/Application Support and /Library/Application Support/​
    The Library Folder you want is the one you can access directly from your Macintosh HD (see below)
    If you can go direct to your Macintosh HD, then you should be able to see the Library folder in there.
C. Reinstall KeyShot
Use the full installer (not an update installer) when performing fresh installs or full reinstalls.
  1. Download and Re-install KeyShot using the links below.
    1. You can find the newest version of KeyShot Studio here.
    2. You can find older versions of KeyShot here.
  2. Go through the registration wizard, enter your license information, and KeyShot should be up and running.
  3. If activation requires a node‑locked license file, select “I have a node‑locked license file” during activation and load the .lic file.
