How to reinstall KeyShot Studio
Best practice to reinstall KeyShot Studio
Procedure
A. Uninstall KeyShot
- Windows: Uninstall KeyShot through Add/Remove Programs.
- macOS: Delete the KeyShot application from the Applications folder.
B. Remove resource and application data folders
- Windows default locations to remove or back up:
- C:\Users<UserName>\Documents\KeyShot
- C:\Users\Public\Documents\KeyShot
- C:\ProgramData\Luxion\KeyShot
- C:\Users<username>\AppData\Local\Luxion\KeyShot
- macOS default location to remove or back up:
- /Library/Application Support/KeyShot
- Tip: Move resource folders to the desktop for backup if needed before deleting.
C. Reinstall KeyShot
Use the full installer (not an update installer) when performing fresh installs or full reinstalls.
- Download the latest release full installer from your KeyShot Account.
- If you require older versions, download a previous release available.
- Run the full installer and complete the registration/activation wizard.
- If activation requires a node‑locked license file, select “I have a node‑locked license file” during activation and load the .lic file.
