How to reinstall KeyShot Studio
Best practice to reinstall KeyShot Studio
Procedure
A. Uninstall KeyShot
  1. Windows: Uninstall KeyShot through Add/Remove Programs.
  2. macOS: Delete the KeyShot application from the Applications folder.
B. Remove resource and application data folders
  • Windows default locations to remove or back up:
    • C:\Users<UserName>\Documents\KeyShot
    • C:\Users\Public\Documents\KeyShot
    • C:\ProgramData\Luxion\KeyShot
    • C:\Users<username>\AppData\Local\Luxion\KeyShot
  • macOS default location to remove or back up:
  • Tip: Move resource folders to the desktop for backup if needed before deleting.
C. Reinstall KeyShot
Use the full installer (not an update installer) when performing fresh installs or full reinstalls.
  1. Download the latest release full installer from your KeyShot Account.
  2. If you require older versions, download a previous release available.
  3. Run the full installer and complete the registration/activation wizard.
  4. If activation requires a node‑locked license file, select “I have a node‑locked license file” during activation and load the .lic file.
