How to Troubleshoot Issues with the Migration Assistant After Upgrading to KeyShot Studio 2025
What to Do If You Aren’t Prompted to Use the Migration Assistant After Upgrading to KeyShot Studio 2025
Issue
Users may encounter an issue with the Migration Assistant not working when upgrading to KeyShot Studio 2025.
Environment Details
- KeyShot Studio 2025
Resolution
When you install a new version of KeyShot Studio and open it for the first time, you should have the opportunity to migrate all your resources and settings to the newer version.
The Migration Assistant should pop up if you have the previous version of KeyShot Studio installed on the same device. If it did not appear, you can retry setting up KeyShot Studio 2025 to prompt you for migration by following the steps below.
Delete the Settings.xml File
Mac Instructions:
- Click on "Go" in the Finder bar, then click on "Computer."
- Open "Macintosh HD."
- Open the "Library" folder.
- Open the "Application Support" folder.
- Open the "KeyShot [version]" folder.
- Look for the
KS[version]Settings.xmlfile and delete it.
Windows Instructions:
- Go to one of the following destinations:
C:\Users\Public\Public Documents\KeyShot [version]C:\Users\[YourUserName]\Documents\KeyShot [version]
- Look for the
KS[version]Settings.xmlfile and delete it. - Relaunch KeyShot. If prompted, DO NOT migrate any settings from older versions of KeyShot.
Once the file is deleted, launch KeyShot Studio again. It should ask if you want to migrate the settings and resources from the previous version. If it does not, a fresh install may be necessary.
How to Perform a Fresh Install
Uninstall KeyShot Studio
- Windows: Uninstall through Add/Remove Programs.
- Mac: Uninstall by going to the Applications folder and deleting the KeyShot app.
Make sure to delete the KeyShot resources folder. If you wish to back up your resources, move the folder to the desktop.
- Windows Default Locations:
C:\Users\[UserName]\Documents\KeyShotC:\Users\Public\Documents\KeyShot- Delete
C:\ProgramData\Luxion\KeyShot - Delete
C:\Users\%username%\AppData\Local\Luxion\KeyShot
- Mac Default Location:
/Library/Application Support/KeyShot
Download and Reinstall KeyShot Studio
Download the full installer (not the update installer) from the links below:
Go through the registration wizard, enter your license information, and KeyShot Studio should be up and running.
If you have any questions or need further assistance, please contact KeyShot Support.
