title: Issue with Multi-Material Sub-Materials with Occlusion texture
description: Issue with Multi-Material Sub-Materials when an Occlusion texture is applied to the opacity.
[Skip to content](https://support.keyshot.com/en/knowledge-base/issue-with-multi-material-sub-materials-with-occlusion-texture#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
 Tell us what's happening
# Issue with Multi-Material Sub-Materials with Occlusion texture
## Issue with Multi-Material Sub-Materials when an Occlusion texture is applied to the opacity.
### Issue
Library models created in KeyShot 2023.3 have an issue with Multi-Material Sub-Materials when an Occlusion texture is applied to the opacity.
The Occlusion connected to a sub-material as an opacity map is broken in 2023.3 and 2024.1 specifically if the model was created in KeyShot 2023. If the model is created in 2024, it works fine.
### Environment Details
- KeyShot
    - 2023.3
### Workaround
Assigning a new identical material fixes the issue in both KeyShot 2023 and KeyShot 2024
keyshot.com Help Center
Copyright © 2026, KeyShot
