title: Issue with Weaving Command in KeyShot Studio - RealCloth Application
description: Resolving Issues with the Weaving Command and RealCloth in KeyShot Studio
[Skip to content](https://support.keyshot.com/en/knowledge-base/issue-with-weaving-command-in-keyshot-realcloth-application#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
 Tell us what's happening
# Issue with Weaving Command in KeyShot Studio - RealCloth Application
## Resolving Issues with the Weaving Command and RealCloth in KeyShot Studio
### **Issue**
The weaving command appears to be stuck or overestimating the complexity of the calculations in KeyShot Studio when applied to a model with RealCloth.
### **Environment**
- KeyShot Studio (Any Version)
### **Cause**
RealCloth can occasionally cause performance issues, particularly when the calculations for the weaving command are complex or overestimated. This can lead to the system becoming stuck during the process.
### **Resolution**
1. **Open the Scene in "Recovery Mode"**
     - Open KeyShot Studio and go to the **Help** menu.
     - Towards the bottom of the Help menu, you will find the option to open the scene in **Recovery Mode**.
     - This allows you to load the scene without triggering the RealCloth calculations and make any necessary adjustments.
2. **Disable or Remove RealCloth**
     - Once in Recovery Mode, you can safely disable or remove the RealCloth from the scene. This will resolve the issue with the weaving command.
By following these steps, you should be able to regain control of the scene and disable RealCloth to proceed without issues. If the problem persists, please reach out to KeyShot Support for additional assistance.
keyshot.com Help Center
Copyright © 2026, KeyShot
