KeyShot Studio 2025.3+ Minimum System Requirements
What are the minimum system requirements for running KeyShot Studio 2025.3+
The main difference from KeyShot Studio's 2025.2 requirements is that the minimum NVidia GPU driver version is bumped up to 576.52.
For AMD GPUs, it remains 23.3.
Platform
  • 64-bit platform
  • Windows
    • Windows 10 (at least 22H2) - Windows 11
    • Windows Server 2019 - Windows Server 2022
  • MacOS
    • Ventura 13 - Sequoia 15
  • Linux (Network Rendering only)
    • Ubuntu 18.04 LTS(5.4 kernel) - Ubuntu 21.04 (22.04 kernel)
    • Other distributions with glibc version 2.23
RAM
  • minimum: 4GB RAM
  • recommended: 16GB RAM and up
CPU
  • Quad-core CPU1'
  • Intel or AMD 64-bit processor with SSE4.1 or higher
GPU
  • OpenGL 2.0 capable system23
  • For the GPU Mode
    • Nvidia
      • Maxwell architecture or higher
        • Recommended architecture is Turing or newer
      • Ideally at least 8GB of dedicated VRAM
      • Consumer/Gaming Cards:
        • GeForce RTX: 20-Series, 30-Series, 40-Series, 50-Series3
        • TITAN RTX
      •  Professional/Workstation Cards:
        • RTX A-Series: A2000 to A6000
        • Quadro Series: GV100, GP100, P400+, P1000+, P3200+, M2000+
      • Minimum driver version: 576.52
      • KeyShot Studio GPU mode supports memory scaling for setups with multiple GPUs connected with NVIDIA NVLink. For example, two NVIDIA Quadro RTX 8000 GPUs will provide a combined 96 GB of GPU memory. When you have multiple GPUs connected with NVLink, you will see a difference in the available GPU Memory within the Heads Up Display in the Real-time view.
    • AMD
      • RDNA 3 architecture and newer
      • Radeon RX 7600 or above
      • Minimum driver version: 23.30
      • Multiple GPUs can be used to improve performance.
        Be aware that memory sharing is not supported and the implementation does not support AMDs MGPU or CrossFire features.
  • For AI Shots:
    • KeyShot recommends all NVIDIA RTX GPUs that launched in the last three years and have at least 16GB of VRAM. Newer cards with more VRAM are preferable.
      While running AI Shots on the CPU and with AMD (RDNA3 and newer, dedicated GPUs only) and Apple (ARM-based) GPUs is possible, NVIDIA GPUs currently offer by far the best performance. The amount of VRAM determines the maximum resolution of generated images.
Display Device
  • 1080p/15.6” or higher
Network
  • Internet connection (to activate product)
[1] KeyShot will utilize all available CPU cores. Therefore, more CPU cores/threads will produce faster rendering times.
[2] While KeyShot doesn’t require GPU for rendering, certain UI elements in KeyShot require a GPU with support for OpenGL 2.0 and up.
[3] Blackwell cards require a CUDA update that is not yet available in KeyShot Studio 2025.2, but is included in 2025.3 and the beta.
Please note that the Beta might still be prone to bugs and is not supported, so it is recommended to install it and its resource folder to a separate location and to not use it for production work, or at least keeping a healthy amount of backups.
https://download.keyshot.com/keyshot2025/beta/keyshot_studio_win64_2025.3_14.2.0.125_beta.exe
