title: How to change the KeyShot Floating License Port Number
description: Changing KeyShot Floating License Port Number
[Skip to content](https://support.keyshot.com/en/knowledge-base/knowledge/changing-keyshot-floating-license-port-number#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
 Tell us what's happening
# How to change the KeyShot Floating License Port Number
## Changing KeyShot Floating License Port Number
Follow these steps to change the port number for the Floating License Server.
### Prerequisites
- KeyShot
- License Server Application
- Windows Admin/Network Admin privileges
### Procedure
#### How to change Port Number with Luxion License Server.
1. Start the *Luxion License Server* application.
2. Go to the *Install License* tab.
3. Click **Set Server Ports**
     1. *FlexLM Port:* Change this to avoid port conflicts if you have other license servers on the same machine. (Default: 27000)
     2. *Daemon Port:* This is only used for network setups with a Firewall. If a Firewall is used, both ports need to be set and opened in the Firewall.
4. Click **OK.**
5. Click **Reread License File** to make sure the changes are applied.
#### How to change the ports manually
1. Open your KeyShot floating license with a text editor.
2. Look for the Server line.
3. After the MAC address add your port number. (Default port 27000)
4. You can also add a port to Vendor Daemon by putting PORT= ####
   Here is a sample file with the server port set at 27003 and the Daemon port set to 27004:
   \# CUSTOMER KEYSHOT
   \# SERIAL FPTESTING
   SERVER KEYSHOTSERVER 123456789101 27003
   VENDOR LUXION PORT=27004
   FEATURE keyshot2 LUXION 2025 permanent 9 DUP\_GROUP=UHD BORROW=720 \\
       SIGN="1247 5A57 256F 4DD7 DB21 3DA8 3CAE FDC4 C704 86DB A02C \\
       1856 92E8 F434 3915 0E1E 6B16 1033 50B8 A383 1361 43D1 66CF \\
       3D25 A2C1 911C B1AA 4CCA 2D2C BC7B"
5. After adding ports save your changes.
6. Open *Luxion License Server*.
7. Go to **Install License** Tab.
8. Load KeyShot floating license.
### Additional Resources
- See more information on Floating license set up in our manual [here](https://manuals.keyshot.com/kss2025/manual/pro-floating-installation.html)
keyshot.com Help Center
Copyright © 2026, KeyShot
