Embedding KeyShot Studio XR into WordPress
How to embed pre-rendered KeyShot Studio XR and Configurator content into WordPress.
Embedding KeyShot XR into WordPress
PrintAfter you have created the KeyShotXR, you will find the files in your KeyShot Resources folder under Animations or in the location you selected in the KeyShotXR Wizard.
Displaying the KeyShotXR on a WordPress website is much like displaying a KeyShotXR on any website with static pages. If you want to include the KeyShotXR or Web Configurator in your WordPress site you can embed it using a WordPress plugin or you can simply add it via an iFrame.
Prerequisites:
Location: Before you can embed your KeyShotXR or Web Configurator into your WordPress site, you need to make it available online. Upload the entire KeyShotXR or Web Configurator folder to your web server. (E.g. uploading my_keyshotxr folder to /srv/www/wordpress/xr/ would display the KeyShotXR at yourwebsite.com/xr/my_keyshotxr/)
NoteYou will need FTP/SFTP access to your webserver or request your site admin to upload for you.
Embed a KeyShotXR
When you render your KeyShotXR the folder will also include instructions.html. Here you can find a section of code that almost can be copied directly into the WordPress editor on the page/post you want to embed it into. All you need to edit is the src URL so it points to the location on the webserver
Upload the KeyShot XR folder to your webserver
Copy the KeyShotXR code found in the instructions.html file
Log in to the admin panel of your WordPress site and select/create the page/post where you want the KeyShotXR to appear.
Ensure that you select the Text tab (not the Visual tab) on the WordPress post/page edit screen.
Paste the code from the instructions file into the editor.
Make sure the src URL location of the HTML file in the code matches the location of the upload.
If you are uploading to a secure website with SSL, make sure to use HTTPS instead of HTTP in the src URL.
Details
The styling and div are around the iframe to ensure that the element works in a responsive layout. It will adapt to the width of the container, without losing the aspect ratio.
Tables can't be imported directly. Please insert an image of your table which can be found here.
<div style="max-width: 1000px; max-height: 1000px">
<div style="left: 0px; width: 100%; height: 0px; position: relative; padding-bottom: 100%; overflow: hidden;">
<iframe style="position: absolute; top: 0px; left: 0px; height: 100%; width: 1px; min-width: 100%;" src="https://mywebserver.com/my_keyshotxr.html" frameborder="0" scrolling="no" allowfullscreen="allowfullscreen"></iframe>
</div>
</div>
Replace following values
max-height/max-width: enter the size you rendered the KeyShotXR in
padding-bottom: the ratio between height and width in %. In this example it is 100% as the ratio is 1:1, a ratio of 16:9 would be 56.25%
src: enter the location of your KeyShotXR on the webserver.
Examples
Embed a Web Configurator
Upload the Web Configuration folder to your web server
Log in to the admin panel of your WordPress site and select/create the page/post where you want the KeyhotXR to appear.
Paste the code below into this area.
Make sure you replace the highlighted values to match your Web Configurator.
<iframe src="https://mywebserver.com/my_webconfigurator.html" frameborder="0" scrolling="no" style="max-width: 1600px; max-height: 900px; height: 100%; width: 100%;"> </iframe>
Replace following values:
max-height/max-width: enter the size you rendered the Web configurator in
src: enter the location of your Web Configurator on the web server.
