Exiting Due to Signal 33 Exit Reason 1
When trying to load a floating license file on your Macintosh computer and it fails to start, looking at the log file you may see the error below.
(lmgrd) Unknown Hostname: (HostName) specified in the license file is not available in thelocal network database(lmgrd) EXITING DUE TO SIGNAL 33 Exit reason 1
This error indicates that your HostName does not match that of your System Preference HostName. So the license server is unable to start because of the difference.
Steps to Resolve:
- Open Luxion License Server software and make sure to Stop the service.
- Open your System Preference window
- Click on Sharing button and make a note of your Hostname.
- Open your keyshot_floating_xxxxxx.lic and find your Hostname.
- Make sure that they match.
- Open a Terminal window and type in Hostname hit Enter/ Return.
- Your current Hostname should show for you to see.
- If Hostname doesn't match, follow the instructions below.
- In Terminal window you will type the instructions that follow:
- sudo scutil --sudo scutil --set HostName <new host name>
- Use the HostName in the Sharings settings that you located earlier for <new host name>
- Enter your password and press Enter/ Return
- Your HostName will print out
- Your HostName should match your Sharings settings HostName
- Open your Luxion License Server and load correct floating license and start your license server up.
*Note:* Check to see if you are able to connect to your floating license. If you are still not able to connect send us your Luxion.log file for further resolutions.
