title: How to borrow KeyShot floating license and return the license
description: The Instructions below are good for either borrowing or returning a floating license to your KeyShot license server.
[Skip to content](https://support.keyshot.com/en/knowledge-base/knowledge/how-to-borrow-keyshot-floating-license-and-return-the-license#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
 Tell us what's happening
# How to borrow KeyShot floating license and return the license
## The Instructions below are good for either borrowing or returning a floating license to your KeyShot license server.
### How to Borrow and Return a Floating Seat
How to borrow a license:
1. Open KeyShot floating client and connect to license server.
2. Go to top Menu and click
     1. (*Windows*)  **Help** \> **Borrow Floating License**
     2. (*Macintosh*) **KeyShot** \> **Borrow Floating Licnese**
3. Select a return date and click **OK**.
4. You will recieve a confirmation message. Click **OK**.
How to return a borrowed license:
1. Open KeyShot floating client on the same network as your KeyShot floating license server.
     1. (*Windows*) **Help** \> **Return** **Borrowed Floating License**
     2. (*Macintosh*) **KeyShot** \> **Return Borrowed Floating Licnese**
3. You will receive a confirmation message. Click **OK**.
**Note:**
The client and server must be connected during the borrowing and returning process.
**Extra Instructions:** When you are not able to return the floating license because it was after expired date or server was updated while license was borrowed follow [this link](https://support.keyshot.com/en/knowledge-base/knowledge/keyshot-floating-license-stuck?hsLang=en) for help to remove the seat.
keyshot.com Help Center
Copyright © 2026, KeyShot
