title: KeyShot floating license won't start
description: When trying to load your KeyShot floating license and it fails to start up, you can look at the Luxion log file for more information. When you open the Luxion Log file and if you happen to see any mes
[Skip to content](https://support.keyshot.com/en/knowledge-base/knowledge/keyshot-floating-license-wont-start#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
 Tell us what's happening
# KeyShot floating license won't start
1. Start Luxion License Server (if not already opened)
2. Go to the **Install License** tab
3. Click **License Folder**
     1. Your License folder will open.
4. Open the Luxion log file located in that folder.
When you open the Luxion Log file and if you happen to see any messages like the one below.
License Manager: can't initialize: Cannot find license file.
The license files (or license server system network addresses) attempted are listed below. Use LM\_LICENSE\_FILE to use a different license file, or contact your software provider for a license file.
- Filename: "C:\\flexlm\\license.dat"
- License Path: "C:\\flexlm\\license.dat"
- FlexNet Licensing error: -1,359
- System Error:2 No such file or directory
- Using license file "C:\\flexlm\\license.dat"
Can you follow the steps below to resolve the licensing issue?
1. Open **LMTOOLs** and select the **Luxion License Server** from the list.
2. Go to **Config Services**.
3. Click on **Remove Services** to remove the KeyShot License.
4. Open **Luxion License Server**.
5. Click on the **Install License** tab.
6. Click on **New License**.
7. Select your **KeyShot Floating License** file.
If you are still having issues after this send us the Luxion log file by submitting a ticket to in our Support Portal.
keyshot.com Help Center
Copyright © 2026, KeyShot
