KeyShot Invalid Login Error Message
This article details how to troubleshoot invalid login error messages with your KeyShot Cloud account
Issue
Issue 1
When accessing KeyShot Cloud or Portal, especially for the first time, it is not unusual to receive an invalid login error message. Users will also be alerted to a possible CSRF attack:
Issue 2
The customer portal page infinitely refreshes in a loop.
Environment Details
- Customer portal page
- Any web browser
Resolution
Do not be alarmed by the attack error message if that is what you see, KeyShot has not been compromised in any way. There are a various reasons why this error message can appear. The most common is a discrepancy between the system clock and your local time.
If you notice that the internet time is showing your company name, then it might be syncing to a server on your network and you would need to ask your IT team to update the time as there can be an issue if the time falls behind even 1 minute.
Please confirm that your computer's clock is accurate.
Go to the bottom right-hand corner on the screen > right-click the date on the task bar and select the option to "Adjust date and time".
You can then sync it up to the internet time.
Then refresh your browser by pressing CTRL + F5 or Command + R. This will clear any cached data.
You should now be able to log into the KeyShot Portal.
If you are still experiencing login issues, please contact support for further assistance.
