title: How to activate your license through the subscription portal
description: Here is a step-by-step guide on how to activate your subscription license using your cloud.keyshot.com login.
[Skip to content](https://support.keyshot.com/en/knowledge-base/knowledge/keyshot-license-portal#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
 Tell us what's happening
3. [Node-Lock](https://support.keyshot.com/en/knowledge-base/license-support?hsLang=en#node-lock)
# How to activate your license through the subscription portal
## Here is a step-by-step guide on how to activate your subscription license using your cloud.keyshot.com login.
### Issue
KeyShot trials are now available via subscription through portal.keyshot.com
### **Environment Details**
- KeyShot
    - Any version
### Resolution
1\. Either when first launching KeyShot or activating your license through the 'Help' option, you will be given the options:
- Activate my License
- Get a Trial
2\. Selecting 'Activate my License' will allow you to activate your license using a serial code, an existing license file, connect to a Floating License server, or through your subscription.
3\. Select 'I have a subscription'.
![](https://support.keyshot.com/hubfs/Knowledge%20Base%20Import/s3_amazonaws_comcdn_freshdesk_comdatahelpdeskattachmentsproduction60032709713original34zKnDJ58PkTgN9gqMydPjlfLz55BvXbZQ.png)
![](https://support.keyshot.com/hubfs/Knowledge%20Base%20Import/s3_amazonaws_comcdn_freshdesk_comdatahelpdeskattachmentsproduction60032709714originalw7m4ZeeLDiww2ldGJ_2MsJpIUqhgPgNB9g.png)
4\. This will give you access to KeyShot no matter where you are, without having to deactivate/re-activate your license.
keyshot.com Help Center
Copyright © 2026, KeyShot
