title: Pivot point
description: If your animation contains multiple pivots, we recommend structuring your scene tree hierarchy in a top-down manner. This allows you to apply a single rotation to a group instead of multiple animation
[Skip to content](https://support.keyshot.com/en/knowledge-base/knowledge/pivot-point#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
 Tell us what's happening
3. [How-To](https://support.keyshot.com/en/knowledge-base/technical-support?hsLang=en#how-to)
# Pivot point
### Animate Multiple Pivot Points
 Print
If your animation contains multiple pivots, we recommend structuring your scene tree hierarchy in a top-down manner. This allows you to apply a single rotation to a group instead of multiple animations to each part.
For more information about re-organizing your scene tree hierarchy, click [here](https://luxion.atlassian.net/wiki/display/K6M/Regrouping+Parts).
**How to animate multiple pivot points:**
The current system works best with a top-down scene tree hierarchy where you have parent groups and parts or sub-groups as children. If the children need to follow the parent group, then a single animation is applied to the parent group.
The diagram below shows an ideal top-down scene tree hierarchy.
![](https://support.keyshot.com/hubfs/Knowledge%20Base%20Import/s3_amazonaws_comcdn_freshdesk_comdatahelpdeskattachmentsproduction60001078367originalQk1VvSjZjX2C0XUW1IodUEq05iN9WVN7WA-2.png)**Level 0** is the bottom part level (a chain link or a pivot point).
**Level 1** is each subgroup by itself.\*
**Level 2** is a group that contains only Subgroup 3 and Subgroup 4.
**Level 3** is a group that contains Subgroup 2 and Level 2.
**Level 4** is your top group.
\* Each subgroup is composed of parts and a single pivot point (these are the children).
**Rules:**
**1.** If you wish to apply the same rotation\*\* animation to all parts in a subgroup, then you apply a single rotation to the subgroup.
**2.** If you wish to apply the same rotation animation to multiple subgroups, then you apply a single rotation to the level that contains the subgroups.
**3.** You should only apply animations to an individual part (at Level 0) if and only if the animation will not be applied to the entire subgroup.
\*\*"same rotation animation" = a rotation around a specific axis and pivot point that starts and ends at exactly the same time for all parts.
keyshot.com Help Center
Copyright © 2026, KeyShot
