When KeyShot floating license give license too old error
If you receive an error message indicating that your KeyShot floating license server is outdated when you try to connect to your KeyShot floating license, this article provides instructions on how to resolve the issue
Issue
If you encounter an error message stating that your KeyShot floating license server is too old when attempting to connect to your KeyShot floating license, it means that the LMGRD and vendor daemon LUXION files are outdated.
Environment Details
  • KeyShot
    • Any version
Resolution
Updating your Luxion License Server.
1. Download the server software for your computers OS.
    1. Windows Server.
    2. Macintosh Server.
    3. Linux Server.
2. Install the server Software
    1. The installer will remove and upgrade the old license server or prompt you          if an older installation has been found.
Once you have Update your Luxion License Server with the current supported file it should resolve the issue with the error that your floating license server is too old.
