Optix error: 7012 (Disk cache database error)
Issue
When trying to activate GPU mode, user gets an error message saying 'Optix error: 7012 (Disk cache database error)
Error: Optix error: 7012 (Disk cache database error)
Environment Details
- KeyShot
- Any version
- Windows computer with GPU Card
Cause
- There may be an issue with the optix7cache.db file
Resolution
Solution 1:
First, make sure that KeyShot is closed.
Solution 2:
Try a Fresh Install if the other options do not work (see instructions below).
Please try a fresh install using the full installer:
Uninstall KeyShot.
Windows: Uninstall through Add/Remove Programs.
Make sure to delete the KeyShot resources folder
Note: Move it to the desktop if you wish to back up your resources.
Windows Default:* C:\Users\UserName\Documents\KeyShot or
* C:\Users\Public\Documents\KeyShot
* Delete C:\ProgramData\Luxion\KeyShot folder
* Delete C:\Users\%username%\AppData\Local\Luxion\KeyShot folder
Download and Re-install KeyShot using the links below.
For this step, you’ll need the full installer (not the "update" installer).
You can find the newest version of KeyShot here. You will need to either enter your information or login to your KeyShot Cloud Account to access the installers.
You can find older versions of KeyShot here.
Go through the registration wizard, enter your license information, and KeyShot should be up and running.
