title: Unable to Change Job Status in KeyShot Network Monitor
description: Troubleshooting greyed-out job options such as Pause, Priority changes, and Delete
[Skip to content](https://support.keyshot.com/en/knowledge-base/unable-to-change-job-status-in-keyshot-network-monitor#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
 Tell us what's happening
3. [Network Rendering](https://support.keyshot.com/en/knowledge-base/technical-support?hsLang=en#network-rendering)
# Unable to Change Job Status in KeyShot Network Monitor
## Troubleshooting greyed-out job options such as Pause, Priority changes, and Delete
### **Issue**
Users are unable to change the status of a job in the KeyShot Network Monitor. Right-click options such as **Pause**, **Increase Priority**, **Decrease Priority**, and **Delete** are greyed out and inaccessible.
### **Environment Details**
- **KeyShot Network Monitor**
- **Server Role:** Both Manager and Worker
- **OS:** Windows and macOS
### **Resolution**
This issue may occur if the administrator account lacks proper permission settings within the Network Monitor interface, despite being signed in as an admin.
1. **Verify Admin Permissions in User Settings:**
     - Open the **KeyShot Network Monitor**.
     - In the **Monitor window**, click on the blank space next to your **Username**.
     - Select **User Settings** from the dropdown.
     - Confirm that your user role is set to **Admin**.
2. If admin rights are correctly assigned and the issue persists, please send us your **Network Monitor logs** so we can investigate further.
### **How to Locate and Send Network Monitor Logs**
Please collect logs from the version of KeyShot you are currently using.
**Windows:**
1. Open File Explorer.
2. Copy and paste each of the following paths into the address bar and locate the folder named `KeyShot # Network Monitor`:
     - `%LocalAppData%\Luxion`
     - `%UserProfile%\Documents`
**macOS:**
1. Open **Finder**.
2. Click **Go** \> **Go to Folder**.
3. Enter the following path:
     - `~/Library/Application Support/Luxion/`
Locate and send the `KeyShot # Network Monitor` folder for the version you're experiencing the issue with.
### **Additional Support**
If the problem continues after verifying admin rights and reviewing the logs, please contact the KeyShot Support team by submitting a ticket through the Support Portal, and include the logs you've gathered along with a description of your setup.
keyshot.com Help Center
Copyright © 2026, KeyShot
