title: Understanding the “Retain Instance-Level Naming” Import Option
description: "Understanding the “Retain Instance-Level Naming” Import Option\n\nHow instance-level naming affects imported parts in KeyShot."
[Skip to content](https://support.keyshot.com/en/knowledge-base/understanding-the-retain-instance-level-naming-import-option#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
 Tell us what's happening
# Understanding the “Retain Instance-Level Naming” Import Option
## How instance-level naming affects imported parts in KeyShot.
### Issue
When importing files (e.g., CATPart, CATProduct, CGR), customers may see an import option called **“Retain Instance-Level Naming”** in the **Materials and Structure** settings. This option does not appear for certain formats such as STL. Users have asked what this setting means and whether part names inherit from the parent part names.
### Environment
- **KeyShot Studio (Any version)**
- **Windows and MacOS**
### Cause
Some CAD applications support **instances**—objects that are duplicates of an original model but with their own names. For example:
- Original object: `Wheel`
- Instances: `Wheel Front Left`, `Wheel Front Right`, `Wheel Rear Left`, `Wheel Rear Right`
KeyShot can either:
1. Keep the **instance-level names** (e.g., “Wheel Front Left”), or
2. Revert to the **original object name** (e.g., all simply “Wheel”).
The “Retain Instance-Level Naming” option allows users to control this behavior.
### Resolution
- **If enabled:** KeyShot keeps the **unique instance names** defined in the CAD file (e.g., “Wheel Front Left”).
- **If disabled:** KeyShot uses the **original object name** for all instances (e.g., all named “Wheel”).
 This option is **only available for formats that support instancing** (CATPart, CATProduct, CGR). It does not appear in formats like STL, which do not contain instance-level information.
keyshot.com Help Center
Copyright © 2026, KeyShot
