title: White Blowout or Overexposure When Rendering in GPU Mode
description: How to resolve sudden overexposure or washed-out frames when using GPU rendering in KeyShot Studio
[Skip to content](https://support.keyshot.com/en/knowledge-base/white-blowout-or-overexposure-when-rendering-in-gpu-mode#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
 Tell us what's happening
# White Blowout or Overexposure When Rendering in GPU Mode
## How to resolve sudden overexposure or washed-out frames when using GPU rendering in KeyShot Studio
### Issue
When rendering in GPU mode, the scene appears completely blown out—almost as if there’s a full white sun flooding the image. This can affect both the **Real-Time Viewport** and the **final render output**, making scenes unusable.
CPU mode still produces correct results, but GPU rendering is preferred for performance—especially when working with large animation sequences.
### Environment
- **Product:** KeyShot
- **Rendering Mode:** GPU
- **OS**: Windows
Cause
This issue is often related to the **Ground Illumination** setting in the Lighting tab of the Project window. While normally helpful, this setting can sometimes cause excessive brightness when used in combination with certain HDRIs or scene setups—especially in GPU mode.
### Resolution (Best Practices)
#### Disable "Ground Illumination"
1. Open your scene in KeyShot.
2. Go to the **Lighting** tab in the **Project** window.
3. Locate and uncheck the box labeled **Ground Illumination**.
4. Preview your scene again in GPU mode.
This setting often resolves extreme brightness or full white-out issues in GPU renders.
Please reach out to KeyShot Support if you have any other questions.
keyshot.com Help Center
Copyright © 2026, KeyShot
