title: Why does my mixed OS render farm render animations that flicker?
description: If your render farm is made up of both Windows and Mac OS workers, you may see inconsistencies from frame to frame, depending on the worker's OS.
[Skip to content](https://support.keyshot.com/en/knowledge-base/why-does-my-mixed-os-render-farm-render-animations-that-flicker#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
 Tell us what's happening
3. [Network Rendering](https://support.keyshot.com/en/knowledge-base/technical-support?hsLang=en#network-rendering)
# Why does my mixed OS render farm render animations that flicker?
## If your render farm is made up of both Windows and Mac OS workers, you may see inconsistencies from frame to frame, depending on the worker's OS.
#### What is happening?
When building a render farm, there is a general rule of thumb to "never mix kernels".  What is a "kernel" you may ask?  The Kernel is the central code to an operating system.
The way Windows PCs and Macs handle random number generation is different at a kernel level.  Things like noise, procedural textures, or anything that uses a random seed parameter are the most affected by this.
keyshot.com Help Center
Copyright © 2026, KeyShot
