ZBrush Bridge Not Working with KeyShot After Update
Understanding compatibility issues between ZBrush, KeyShot, and the ZBrush–KeyShot Bridge.
Issue
After installing the latest version of ZBrush, the ZBrush–KeyShot Bridge no longer works.
Environment
Product: KeyShot (versions 10)
Platform: Windows/macOS
Cause
ZBrush updates may have broken compatibility with KeyShot 10.
KeyShot 10 has not been updated since July 2021 and will reach end of life on January 1, 2026.
Starting with KeyShot Studio (2023 and newer), the application became versionless, and plugins were updated to recognize “KeyShot Studio” instead of just “KeyShot.”
Resolution
Contact Maxon Support
Since the Bridge is developed by Maxon, any fixes or updates must come from them. Please reach out to Maxon’s support team regarding compatibility with the latest ZBrush release.
Test with a newer version of KeyShot
You can try the latest KeyShot 2025 to verify if the Bridge works as expected.
Use Export/Import as a workaround
If the plugin includes an Export function, try exporting the scene from ZBrush as a
.bipfile and then import it into KeyShot instead of using live linking
