title: How to Transfer your KeyShot Node-lock License to Another Computer
description: This article provides step-by-step instructions on transferring a KeyShot license from one computer to another
[Skip to content](https://support.keyshot.com/en/knowledge-base/knowledge/moving-keyshot-license#main-content)
Show submenu for translations
Open main navigation
Close main navigation
- English
 Tell us what's happening
3. [Node-Lock](https://support.keyshot.com/en/knowledge-base/license-support?hsLang=en#node-lock)
# How to Transfer your KeyShot Node-lock License to Another Computer
## This article provides step-by-step instructions on transferring a KeyShot license from one computer to another
KeyShot serial codes can only be registered on one computer at a time. However, you can transfer your license between two computers by deactivating your license.
Both the currently active computer and the computer you want to move your license to must be connected to the internet.
### Prerequisites
- KeyShot
    - Any Version
### Procedure
WARNING
Do not deactivate your license if it has already reached its End of Life (EoL). Our support team will be unable to reactivate an EoL license. To learn more, see the [KeyShot Product Life Cycle Roadmap](https://support.keyshot.com/en/knowledge-base/keyshot-product-life-cycle-roadmap?hsLang=en).
#### Deactivate your license from one computer:
1\. Open KeyShot on your computer.
2\. Go to **Help** (**Windows**) or **KeyShot** (**Mac**) \> **Deactivate License**. This will deactivate the license and release your serial code from our server.
3\. A window will pop up telling you **Deactivation** was **Successful**.
Follow the appropriate steps below to activate your license on the new computer, depending on whether it is a first-time installation or KeyShot has already been installed in Demo or Trial mode.
#### First-time Installation
1\. Install KeyShot on the new computer and select **Activate your license**.
2\. Fill out your Registration Information.
3\. Enter your serial code in the current window.
4\. Enter your KeyShot XR/Web serial code if you have one. If you do not have one, you can skip this step.
**Note:** If **Activation fails**, save the requested file and send it to [Customer Support](https://support.keyshot.com/tickets-view?hsLang=en).
#### Already Installed on the computer
1\. Open KeyShot and go to **Help** (**Windows**) or **KeyShot** (**Mac**) \> **Activate License**.
2\. Select **Activate your license**.
3\. Fill out your Registration Information.
4\. Enter your serial code in the current window.
5\. Enter your KeyShot XR/Web serial code if you have one. If you do not have one, you can skip this step.
If **Activation fails** Save the request file and send it to [Customer Support](https://support.keyshot.com/tickets-view?hsLang=en).
keyshot.com Help Center
Copyright © 2026, KeyShot
