My KeyShot software is Freezing or Crashing
Crash Right After Launch
New KeyShot releases require the most recent graphics drivers. To check your driver:
1. Launch Windows Device Manager.
2. Go to Display Adapters.
3. Right-click your card and go to Properties -> Driver -> Driver Date.
Your driver should not be more than two months old. To obtain the latest, visit the graphic card manufacturer's web page and search for the latest driver for your card model. DELL users should go through DELL's website to obtain the latest "video" drivers.
Back to Top
Crash/Freeze When Importing or Saving
This crash is normally caused by DELL's Backup and Recovery. On Alienware, this is called AlienRespawn. We've also received reports that NAHIMIC, gaming audios software, causes conflicts.
To fix this issue, you can try the following:
1. Go to your Start menu, click Control Panel -> Programs.
2. Click Uninstall a Program.
3. Find Dell Backup and Recovery or AlienRespawn (on Alienware), or NAHIMIC.
4. Right-click and select Uninstall.
5. Follow the prompts until the utility uninstalls and re-start your computer
Back to Top
Crash While KeyShot Is Idle
We've received reports that Raptr, screen recording software, and NAHIMIC, gaming audio software, cause similar crashes.
We recommend uninstalling Raptr and removing the faulting module: C:\PROGRA~2\RAPTRI~1\PlaysTV\ltc_game64-116096.dll
Back to Top
Crash Only with a Certain User Login
According to Microsoft support, the .config file may be corrupt. To fix this, delete your user.config file. For more information, click here.
Back to Top
Your Program Can't Start Because MSVCP100.dll is missing
If you are receiving the message below:
"The Program can't start because MSVCP100.dll is missing from your computer, Try reinstalling the program to fix the problem."
Then, you will need to download and install one of these small updates:
Microsoft Visual C++ 2010 SP1 - PC 32-bit
Microsoft Visual C++ 2010 SP1 - PC 64-bit
Please contact KeyShot support by submitting a support ticket in the support portal if none of these solutions resolve your issue.
